what could be the problem besides the coil packs
2003 Volkswagen Passat Misfire
To help isolate misfire problems, swap parts in question from the cylinders misfiring with the ones that aren't. When the codes shows movement to the other cylinder, you have your bad part.
This isn't always posssible such as a bad head gasket, but can eliminate, plugs, wires, fuel injectors anyways.
Suggested Repair
Because cylinders 3 and 4 are adjacent, check shared causes such as a vacuum leak, low compression, or a head gasket leak between those cylinders. Swap coils, wires, and injectors with good cylinders to see if the misfire follows a part. Address the flashing check engine light promptly to limit catalytic converter damage.
Conversation Summary
A 2003 Volkswagen Passat 1.8T has a flashing check engine light and random misfires on cylinders 3 and 4 after the spark plugs were replaced. Experts advised looking for anything those neighboring cylinders share, including a vacuum leak, poor compression, or a blown head gasket, and swapping suspect ignition or injector parts with good cylinders to see if the misfire moves. They also noted a flashing light can damage the catalytic converter.
