2001.5 Passat 2.8 Wagon
a little over 100K mi
Many Thanks,
John
Check the fuses, clean the brown ground-wire connection on the firewall, and confirm the small positive battery wires are secure. Test for spark at the coil wire; no spark is more likely an ignition module than a failed ECU. If spark is present, check whether the external driver-side fuel pump runs while cranking and tap it gently if it does not. Do not disturb the fuel-injection distribution head under the air cleaner.
The owner of a 2001.5 Volkswagen Passat 2.8 wagon charged the battery without disconnecting it. The engine cranks but will not start, and the owner suspects no spark and possible ECU damage. Dashboard fuses were already checked and found good. The expert advised cleaning the firewall ground connection, verifying battery wiring, testing for spark and fuel, and checking the external fuel pump, while saying the ECU is unlikely to be damaged.
