98' VW JETTA, FUEL PUMP FUSE KEEPS POPPING
1998 VOLKSWAGEN
JTTARNA
I drive a 98' Jetta with 91,000 miles on it. I went around a turn and my car died out. I replaced the fuse for my fuel pump and it ran for a block and popped. I replaced the fuel pump and filter and the problem still occurs. It runs fine at an idle but once i start driving, the fuse pops again.....any suggestions?
Jan 13, 2007 at 4:33 AM
SERVICE WRITER
  • 9,123 POSTS
Thanks for the donation, It is appreciated!
What size engine?
Sounds like there is a short in the fuel pump circuit.
I may not be much help, but there should be some on the way.
Jan 13, 2007 at 9:04 AM
BRUCE HUNT
  • 3,754 POSTS
I would look at the circuit as mentioned by Service Writer. Now the question is where the circuit runs through the car. What would I do?
I would run a new positive wire to the rear of the car and cut the supply power and hook to the new wire. If the car works fine and it eliminates the problem I would either leave it or test the wire to start narrowing down the location of the short. This is a short.
Jan 13, 2007 at 9:34 AM
SLS8203
can u tell me where the fuse for the fuel pump is located?
Apr 21, 2007 at 11:27 AM
