1996 VW Jetta Radio Shows SAFE
1996 VOLKSWAGEN
MRSJETTA
Mileage 122,000. Just had one of my oxygen sensors replaced last night. Now my factory installed radio reads "SAFE" on the digital screen. Won't scan or work at all. Am loosing my mind as I need my drive time tunes.
Computer has not been reset yet - when this is done will my problem be resolved? Thanks for your input!
Dec 5, 2006 at 12:08 PM
CARUNDELL
  • 602 POSTS
[quote:6db419bf13="mrsjetta"]Mileage 122,000. Just had one of my oxygen sensors replaced last night. Now my factory installed radio reads "SAFE" on the digital screen. Won't scan or work at all. Am loosing my mind as I need my drive time tunes.
Computer has not been reset yet - when this is done will my problem be resolved? Thanks for your input![/quote:6db419bf13]
Hey mrsjetta,
"safe" on your tune box means the radio has gone into "theft mode" and will occur if there was a battery disconnect, though why the shop would disconn. the battery for an O2 replacement is beyond me. You'll have to call or stop into a local VW dealer with proof of ownership of the car and they can give you the "code" to get the radio back on! Hope this helps!
Regards,
Chris
Dec 6, 2006 at 7:02 AM
KHAY
The same thing happened to our radio, you can simply remove the radio and the code should be on the radio itself.. don't ask me why. But that is where ours was and now it works fine.
Mar 4, 2007 at 4:19 PM
Suggested Repair
The SAFE display means the factory radio entered theft mode, often after a battery disconnect. Take proof of ownership to a VW dealer for the radio code, or remove the radio and check whether the code is printed on the unit, then enter it to restore operation. Resetting the engine computer will not unlock the radio.
Conversation Summary
After an oxygen sensor replacement on a 1996 VW Jetta, the factory radio displayed SAFE and would not scan or play. The expert explained this is theft mode, typically triggered by a battery disconnect, and said a VW dealer can provide the unlock code with proof of ownership. Another owner reported finding the code printed on the radio after removing it and restoring operation that way.
