96 Jetta Won't Start
BENNY HAHA
  • 1996 VOLKSWAGEN
1996 VW Jetta, 2.0L, 295,000
Stalled in rain twice in four months. Now won't start at all.
Replaced cap, rotor, plugs, wires; ignition checked and good, fuses all good, timing belt old but appears tense, intact teeth.
Fuel pressure good at fuel rail.
What's going on here? What can I troubleshoot next?
Saturday, March 4th, 2006 AT 2:03 PM
SCENICWEST
  • 17 POSTS
Hey Ben,
Check your coil. It is located to the left of the brake fluid reservoir. If you're not getting spark, that is the main place I've seen a problem. The coil will run around $125. A 2.0L will die when it is damp or raining outside if the coil is arcing. If you get it running when it is dry out, take something that can squirt water and spray the coil. You'll know if it is the problem or not. You'll see a few arcs and then she'll shut down. This is where I'ld start if you are only having the problem as stated. Let us know what turns out. Oh, if you have to replace the coil, you'll need to use a 10mm wrench and a torq's bit (T30 I think). Good luck!
Tuesday, March 7th, 2006 AT 8:23 PM
BENNY HAHA
  • 6 POSTS
OK, so I've got spark at the distributor. With coil wire removed from cap, put against valve cover, there is orange spark. But still nothing at brand new plugs, with brand new wires, cap, and rotor. Then what?
Tuesday, March 7th, 2006 AT 8:51 PM
SCENICWEST
  • 17 POSTS
Have someone try starting the car (in park if an automatic/neutral if a manual) and see if you can visually see an electrical arc at the coil. You should have a blueish spark at the spark plug. If you continue to have the coil wire disconnected and are checking the spark as you are you are running the chance of smoking the ecu. That's bad. I've seen this happen. You probably just have weak spark.
Tuesday, March 7th, 2006 AT 9:00 PM
MEXICA1964
Ok, what if you have a weak spark, what do you do if that is the case?
Saturday, September 23rd, 2006 AT 4:41 PM
