96 Jetta oil blow by? What dose this mean?
1996 VOLKSWAGEN
KOOLMIKE500
  • 6 POSTS
I was getting an oil change for my 96 jetta GL
2.0 5 speed 180 000kms. They siad that there is oil blow present in the air box. What dose this mean,
and how much will it cost to fix. Thanks.
MIKE D>
Dec 2, 2006 at 3:19 AM
CARUNDELL
  • 602 POSTS
[quote:ee6248d868="koolmike500"]I was getting an oil change for my 96 jetta GL
MIKE D>[/quote:ee6248d868]
Hey mike,
Over time some oil will collect in the air intake ducting and air box. The important question you need to ask and be aware of is "oil consumption". Does the vehicle use allot of oil in between oil changes? (a quart or more) Is there a blue smoke coming out of the tailpipe on acceleration. If not, its not too much of a concern.
Regards,
Chris
Dec 6, 2006 at 7:25 AM
FRIEDEMANN
  • 47 POSTS
It means exactly what it says. Oil is blowing by the rings. It comes with wear. The mechanic should have been more up front with you on is it bad.
The metal parts (piston rings and cylinder walls are in near contact with each other seperated by a skin of oil) This oil slows down the wearing away of the metal parts....but they do wear. As they wear, there is more of a gap between the ring and the wall and compression pressure sneaks past down into the crankcase where the oil is held. Thru the various hoses to releave the pressure in the crankcase this compression would be pumped out into the air cleaner as a visible oily mist Blowby. As the engine gains more miles oil sneaks by the rings upward into the combustion chamber and is burnt with the gas giving you the blue smoke. Engine is worn quite a bit at this stage, meaning an engine job should be happening. With the older cars 70's with the oils that were available , this stuff would be seen around 100,000 miles. With the newer oils, and regualar oil changes the mileage should have increased between engine jobs.
Dec 11, 2006 at 8:48 AM
