2006 Passat Brake Pad wear sensor wiring damage
2006 VOLKSWAGEN
LLEWIS
Hi: I have a 2006 Passat with approx. 40000 miles. I had developed a brake squeak and I removed the front pads to clean them. My mistake was that I forgot to unplug the brake pad wear sensor at the LF brake caliper and I damaged the plug for the wire coming in from the wheel well. The wire end on the brake pad is OK. What I was wondering was if there is a repair kit for the wire end ???? I made a temporary repair but I would rather not leave it that way. Any help you could give me would be appreciated. My dealership did'nt know what I was talking about.. Thanks Alot.
Nov 26, 2007 at 8:03 AM
MERLIN2021
  • 17,250 POSTS
Go to the junk yards, cut the piece off an old wreck, and solder it on to yours...
Nov 26, 2007 at 8:22 AM
  • 55,224 POSTS
Just use regular wiring to fix the damage, no big deal.
Jun 13, 2024 at 8:38 AM
