2003 Other Volkswagen Models Clutch / Gearbox problem
2003 VOLKSWAGEN
42,040 MILES • 4 CYL • 2WD • MANUAL
MRBROCK
Hello
A problem has developed in my VW Bora over the last few days. When depressing the clutch pedal, there is nothing there for about half the travel of the pedal. Then, when the clutch pedal starts to work and kick in, and the pedal is fully depressed, you have to be quite forceful to engage any gear.
Does anybody know if this is a serious problem that will require a replacement clutch and / or gearbox, or if it is a simple case of something needing adjusting?
Any assistance with this query would be greatly appreciated.
Many thanks.
Cheers
Matt.
MATTHEW BROCK
Aug 28, 2008 at 8:20 PM
  • 31,937 POSTS
Hi there,
i don't have this model in the data base, but if it is a hydraulic clutch i would be checking for fluid loss, as if you get air in the system you can get your symptoms, check this first.
Mark (mhpautos)
Aug 28, 2008 at 8:31 PM
