2002 Volkswagen vibration while accelerating
2002 VOLKSWAGEN
128,500 MILES • 4 CYL • FWD • AUTOMATIC
CHRISTOPHER SMITH
I have a 2002, VW Jetta TDI diesel with 128500 miles. While accelerating above 60mph the front end shakes and the shaking increases with higher speed. I recently had a 4 wheel alignment and all 4 tires balanced also new struts and shocks. This did not correct the problem. I checked underneath the vehicle and everything seems to be tight. The vibration stops when I let off the pedal and coast.
I would appreciate some feed back. Thanks.
C. Smith
Dec 3, 2007 at 1:43 PM
ZUE
  • 76 POSTS
Seems you have done all the obvious repairs so far. Here are some more things to consider.
Half shafts can induce vibration into the drive train if they are badly worn. A broken motor mount can induce vibration in the drive under power. Tires not properly bolted (torqued) to the rotors can cause vibration.
Dec 3, 2007 at 2:56 PM
ZUE
  • 76 POSTS
Did you fins a solution to your earlier problem?
Dec 4, 2010 at 10:51 PM
