2002 Volkswagen
2002 VOLKSWAGEN
200,000 MILES • V12 • FWD • MANUAL
SCOTTLARSEN
MY MILAAGE HAS DROPED DRAMATICLY THIS IA A TDI THE WEATHER HAS BEEN VERY COLD AND DONT KNOW IF THIS HAS AFFECTED IT THIS MUCH THE CAR IS WARMED UP VERY WELL AND IS ON THE ROAD AT TIMES 10 HOURS
Dec 1, 2007 at 9:01 AM
DR LOOT
  • CAR REPAIR CONTRIBUTOR
  • 2,311 POSTS
I am not sure where you live, with the problem that you're having sounds like fuel problems, when is the last time you change your fuel filter? us if you do not keep your fuel tank full of fuel in the winter it will accumulate water so replace the fuel filter and make sure you keep your tank full every day and check and make sure your fuel lines are not cracked sucking air
Jan 24, 2009 at 8:21 PM
