2001 Jetta clutch problems
2001 VOLKSWAGEN
STRAWBERRIE_STORM
I'm a 17 year old newly licensed driver and my dad just bought me a 2001 jetta gls vr6 (manual). Everything was fine until yesterday when my engine was revving even when I wasn't touching anything. Today on my way to work, it wouldn't go above 20 mph in any gear. I pulled over shut off the car and restarted it. When I put it back in gear it wouldn't move. I called my boyfriend and told him what happened, he said he thinks my clutch is blown, granted he may be correct but he doesn't know enough about cars for me to trust what he has to say. I was wondering what you think it may be, and if it is the clutch, what I might need and if it's possible to do it as a DIY project because I don't have much money I can go and spend on it. I would appreciate any help you can give me. Thank you so much.
Apr 11, 2007 at 10:13 AM
JGUTKA
go here www.vwvortex.com
Apr 13, 2007 at 9:15 PM
HONDACIVIC94
  • 8 POSTS
[quote:3d0d77aefb="strawberrie_storm"]I'm a 17 year old newly licensed driver and my dad just bought me a 2001 jetta gls vr6 (manual). Everything was fine until yesterday when my engine was revving even when I wasn't touching anything. Today on my way to work, it wouldn't go above 20 mph in any gear. I pulled over shut off the car and restarted it. When I put it back in gear it wouldn't move. I called my boyfriend and told him what happened, he said he thinks my clutch is blown, granted he may be correct but he doesn't know enough about cars for me to trust what he has to say. I was wondering what you think it may be, and if it is the clutch, what I might need and if it's possible to do it as a DIY project because I don't have much money I can go and spend on it. I would appreciate any help you can give me. Thank you so much.[/quote:3d0d77aefb]....if you put vehicle into first gear and release clutch and it will not move it is going to be your clutch and it is not cheap on parts and the labor to do is alot. good luck.
Apr 25, 2007 at 5:26 PM
STRAWBERRIE_STORM
The problem is solved. It cost me $923 to fix. It was $415 for the clutch kit, $455 for the labor, and the rest was tax. It took all of 8 hours once the car was dropped off at the shop.
Apr 26, 2007 at 12:58 AM
