2000 VW Jetta TDI Diesel
2000 VOLKSWAGEN
TXSTANG
My Jetta has about 130K miles on it. Runs good but just doesn't seem to have quite the pickup I feel it should. When I depress the gas peddle completely to the floor it doesn't seem to have very much throttle response. I have to depress the peddle slowly and gradually give it gas or it bogs. I have changed the glow plugs and the glow plug harness which did make the "check engine" light go away. I also removed the throttle body and cleaned it as I heard the EGR valve may be the problem. The gunk buildup was very bad but is now clean. The turbo seems to kick in late once the RPM's get up. I had the timing belt replaced at about 100k. Thanks for your help.
Jan 10, 2007 at 10:37 AM
BRUCE HUNT
  • 3,754 POSTS
I recommend checking the turbo air flow for blockage.
Jan 10, 2007 at 12:20 PM
2CARPRO JACK
  • 11,533 POSTS
You might also want to inspect the vacuum lines at the turbo ( wastegate and such). Does it have proper fuel pressure?
Jan 10, 2007 at 11:29 PM
GIXXERMAN
Check your Mass Air Flow sensor. They go out all the time and will give the same symptoms as you described.
Jason
Jan 12, 2007 at 4:45 AM
