2000 Other Volkswagen Models 2000 Cabrio - Air Conditioning
2000 VOLKSWAGEN
68,000 MILES • 4 CYL • FWD • AUTOMATIC
TURUCHIPA
2000 Cabrio. Cold air not coming out. The blower works, the A/C system has been checked for leaks, vacuumed and recharged. It seems to be an electrical issue, any ideas about this? Thank you.
Jul 4, 2008 at 2:44 AM
KHLOW2008
  • 41,814 POSTS
Hi turuchipa,
Is the compressor working when AC is turned on?
If no, you need to check the relays, compressor clutch or compressor switch.
Jul 5, 2008 at 5:54 PM
TURUCHIPA
Hello KHLow200,
It seems that power is not getting to the compressor. Warm air comes out when you turn the A/C. The relay has been tested and it seems to be ok.
Thank you for your reply I will follow up on the compressor clutch or compressor switch and let you know.
Let me know if you have other suggestions.
Thanks.
Jul 7, 2008 at 7:38 AM
KHLOW2008
  • 41,814 POSTS
Hi turuchipa,
Apply battery current to comperssor clutch wire and if it clicks, the clutch is ok.
Check for power supply to compressor magnetic clutch relay and out put to clutch when AC switch is turned on.
Jul 7, 2008 at 11:56 PM
TURUCHIPA
KHLow2008,
I will perform your suggestions and get back to you. Thank you very much.
Jul 8, 2008 at 1:02 AM
