2000 Volkswagen Jetta Power Loss
2000 VOLKSWAGEN
GREENEGGSANDMOE
Hello, i have a 2000 VW Jetta vr6 with 95000 and since day one it's been giving me all kinds of problems first thing i had to replace the MAF sensor and it was working fine a few days later the check engine light came back and i had the car scaned and the code was P0420 and it reads Emission Workshop the funny thing is that the light would clear and come back and now it's on for good..recently i changed my spark plugs, Oil and Oil Filter and one day later the EPC and the ASR lights came along together and it reads Engine Workshop, i had the car scaned and i got the codes p1128, p1142 and p1101 i dont know what the problem is or were is coming from...i think there might be an air leak but im not sure were it's coming from the car runs good but sometimes it looses power on the engine and then power returns...if u can please help me find the problem on what's going on i would really appreciate it.
Best Reguards Moises Lara :|
Jun 22, 2007 at 12:12 PM
2CARPRO JACK
  • 11,533 POSTS
1128 is system lean bank 1-
1142 is load determination not reached - check MAF, throttle valve control module, fuel pressure
I dont see an 1101 listed.
Definitly look for vacuum leaks, could also be a faulty o2 sensor . Also test the throttle position sensor on the gas pedal by your feet
Jun 24, 2007 at 2:00 AM
GREENEGGSANDMOE
Thanx for having the chance to reply i was wondering if the EPC and ASR lights are very dangerous lights as the come up together and how long would i be able to drive it like that?
Jun 27, 2007 at 1:41 PM
2CARPRO JACK
  • 11,533 POSTS
The EPC is Electronic Power Control,it pertains to the electronic accelerator system. Could possibly lose ability to give the car throttle
ASR has to do with traction control and anti-lock brakes, all of which are safety devices and should be taken care of promptly
Jun 28, 2007 at 1:11 AM
Suggested Repair
Inspect for vacuum leaks and check the MAF, throttle valve control module, fuel pressure, oxygen sensor, and accelerator pedal position sensor. Address the EPC and ASR warnings promptly because electronic throttle response and traction/ABS functions may be affected.
Conversation Summary
The owner of a 2000 Volkswagen Jetta VR6 reported a recurring check-engine light after MAF replacement, code P0420, then EPC and ASR lights with codes P1128, P1142, and P1101, plus intermittent power loss. The expert identified a lean condition and a load-determination fault, recommended checking vacuum leaks, the MAF, throttle control, fuel pressure, oxygen sensor, and pedal position sensor, and said the EPC and ASR warnings involve electronic throttle and traction/ABS safety systems that should be repaired promptly. Code P1101 was not recognized.
