1999 Volkswagon Jetta 96,000 miles
1999 VOLKSWAGEN
JIM P
:cry: My Jetta starter willl not crank sometimes. The battery is new. It will happen randomly. Sometimes after it has been stopped and started 3-5 times. Sometimes when it has not been started in days. Sometimes in the rain. Go back to start the car 10 minutes later or the next day and it starts right up. You will hear the musical sound when you turn the key and the dash idoit lights will come on but the starter will not engage and turn over. I tried starting it in neutral. That did not work. The solenoid that coordinates the brake pedal and allows you to shift out of park was replaced. The starter was checked to see if it was drawing to much but it was not. Thought it could it have something to do with the alarm arming itself and attempted to lock the car without setting the alarm but that did not work. If I bring it a mechanic he finds nothing wrong. Their statement was call me when you are stuck. Help.
Dec 28, 2006 at 7:03 AM
BRUCE HUNT
  • 3,754 POSTS
Intermittent (sp) problems like this will not trip a computer diagnostic exam and unless the problem gets worse it will most likely be a lucky thing to find.
Speaking seriously how about a really basic thing to check. Try unhooking the battery completely and cleaning the terminal connection with a battery cleaner tool. Very cheap with brush at parts store or even Walmart. Even though a connection looks good it will not conduct the juice to the starter but will run lights, fans, etc. Clean them and if you suspect a connection to the battery or the starter, replace.
Jan 8, 2007 at 2:06 AM
