1999 jetta MAF
1999 VOLKSWAGEN
KYCSAILOR
Aloha, still having misfiire problems. With the ignition in the on position (motor not running), should the MAF have any reading? It shows me a airflow of 2.77 g/s with the engine not running. Thought this was kind of odd. Thanks
Oct 29, 2007 at 11:46 AM
BMRFIXIT
  • 19,053 POSTS
[quote:45bc46fb84="kycsailor"]Aloha, still having misfiire problems. With the ignition in the on position (motor not running), should the MAF have any reading? It shows me a airflow of 2.77 g/s with the engine not running. Thought this was kind of odd. Thanks[/quote:45bc46fb84]
Disconnect the sensor and check or try to start
Almost every vw I had needed a mass air flow sensor
And if so replace the air filter
also check the coil
good luck
Oct 29, 2007 at 11:55 AM
