1999 Volkswagen Jetta Coolant Loss
SHINIESTAR19
In my 1999 jetta, the coolant is sucking up to fast. One day Ill fill it up with coolant. Drive it around for two days. After two days I check under the hood. & theres no coolant. I check uder the car for leaks on the ground & theres NO leaking. can you help?
Apr 4, 2006 at 4:19 AM
LOSONE
  • 1,616 POSTS
Pull the plugs and see if you get any water out of the plug holes when you trun the engine over.
The other issue might be a bad heater core. Is the inside right flor wet?? Good luck
Apr 4, 2006 at 8:27 AM
Suggested Repair
Remove the spark plugs and crank the engine to see if coolant comes out of the plug holes, which can indicate an internal leak. Also check whether the passenger-side floor is wet, which may point to a failed heater core.
Conversation Summary
The owner of a 1999 Volkswagen Jetta says coolant disappears after about two days of driving with no visible leak on the ground. The expert suggests checking the spark plug holes for coolant when cranking the engine and checking for a wet passenger floor that could indicate a bad heater core.
