1994 Golf 1.8L fuel smell
1994 VOLKSWAGEN
SCORPY
Hi, I have a 1994 Golf Cl 1.8L, there is a fuel smell when I turn the ventilation Fan On, I don't see any leak anywhere, smells only comes when the fan is on. any suggestions would be apreciated, thank you!
Nov 17, 2007 at 10:47 PM
MERLIN2021
  • 17,250 POSTS
Check the filler pipe for pinholes...common problem, all makes!
Nov 18, 2007 at 12:07 AM
SCORPY
[quote:189f726a0d="merlin2021"]Check the filler pipe for pinholes...common problem, all makes![/quote:189f726a0d]
thank you for your reply,, but where is the filler pipe located, and what does it do!
Nov 18, 2007 at 5:35 AM
MERLIN2021
  • 17,250 POSTS
It's the pipe were you fill the car with gas! Runs between the fender and the tank...
Nov 18, 2007 at 6:15 AM
