1992 Other Volkswagen Models engine stalling
1992 VOLKSWAGEN
12,200 MILES • 4 CYL • FWD • MANUAL
DGANCERES
I have a 1992 VW cabriolet with at standard transmission, it starts fine, but after it warms up and I drive it, it sometimes stalls when i come to a stop and press in the clutch, sometimes it stalls and sometimes it almost stalls but the engine rebounds and it dosent stall. I have read the other post and i don't think my car has a EGR or idle air control valve, any help would be greatly appreciated. thank you
Jul 18, 2008 at 4:40 AM
KLSHIEL
  • 163 POSTS
Well all vehicles have some sort of idle control. I'm not familiar with your particular engine, but I am guessing throttle body injection. By '92 it would have an idle control that would be variable. The question is if it is something the computer is supposed to do or if it is manual. The fact that the engine stalls after it has been warmed tells me that it is computer controlled because that means the engine idles itself up until it is warm. You could try starting the engine and watching the throttle cable until the engine idles down so you can locate where the idle control is and how it works. I know some engines have a minimum idle screw you can adjust where the throttle cable meets the throttle plate. This would patch your problem temporary, but I think you may want to look into it some more.
Jul 18, 2008 at 5:18 AM
