1990 Other Volkswagen Models No Reverse HELP! (Cabriolet)
1990 VOLKSWAGEN
110,000 MILES • 4 CYL • FWD • MANUAL
MAETYN
My car has worked fine until 4 days ago when I tried to put it into reverse. It wouldn't go. It seems like there's something blocking it. I've tried having someone push the clutch in while I manually try to put in in gear via the engine but that didn't work. Every other gear goes in smoothly. I do most of the work on my own but rebuilding a transmission may be out of my league. What can I do?
Mar 25, 2008 at 12:08 PM
MASTERTECHTIM
  • 4,750 POSTS
well if its not a linkage problem then you will have to replace the transmission. try a salvage yard
Mar 25, 2008 at 12:15 PM
