1987 Other Volkswagen Models Venting the cooling system
1987 VOLKSWAGEN
JUST14US
Engine Cooling problem
1987 Other Volkswagen Models 4 cyl Front Wheel Drive Manual 125k miles
How do you, or can you vent the cooling system on a 87 16v VW Scirrocco? I've replaced the water pump, took the thermostat out, replaced the fan temperature sensor, flushed the system. When the car is started it runs fine, no bubbles in the expansion tank, but when it heats up the water starts to boil. Could it be air in the sysem? What could be causing this?
Andy
Oct 30, 2008 at 2:03 PM
  • 31,937 POSTS
Hi there, check that the cooling fans are coming on, and have the radiator cleaned & flow tested first.
mark (mhpautos)
Oct 30, 2008 at 3:49 PM
