1986 Other Volkswagen Models Fuel Filter Replacement
1986 VOLKSWAGEN
165,000 MILES • 4 CYL • 2WD • AUTOMATIC
BSS9158
Engine has not run for several years. I have changed all plugs, plug wires, air filter, oil and filter, and engine started. Has run several times since. Recently will not start. Probable fuel filter blockage. There are two fuel lines coming from the gas tank. Is the line pressurized and are there filters in both lines or just one?
Any other ideas on how to get it to start again?
Dec 2, 2008 at 3:35 AM
DAVE H
  • 13,383 POSTS
you will have to supply us with the exact model VW before we can answer this question .... there will only be one filter .. one of the fuel lines will be a return line .. the other line will be pressureised .. without more info on actual vehicle i cannot help more ?
Dec 5, 2008 at 11:44 AM
