1985 Other Volkswagen Models tranny failed
1985 VOLKSWAGEN
133,000 MILES • 4 CYL • 2WD • MANUAL
HOOP2DOG
i was driving along in my vanagon....i believe that i was in third gear...it seemed to have popped out of gear....i clutched it and put it back into gear to find that none of the gears where there. There was no grinding.....after coasting to a stop....i can shift through all of the gears without using the clutch...there is still no grinding.....I checked the linkage and it is intact up to the tranny housing. I have not had any problems with it slipping out of gear in the past.....Thanks so much for you time and help!!!
Dec 29, 2007 at 2:06 PM
  • 31,937 POSTS
The box will have to come out, i would be checking that the clutch plate hub has not destroyed it self. or you have broken an input shaft.
Mark (mhpautos)
Dec 29, 2007 at 2:21 PM
