1976 Other Volkswagen Models Battery drain and Alternator li
1976 VOLKSWAGEN
ALSCHNEIDER1
Electrical problem
1976 Other Volkswagen Models 4 cyl Two Wheel Drive Manual 108k miles
Stumped....replaced the voltage regulator....i have to disconnect the battery cable to keep the batt from going dead.
Sep 8, 2008 at 3:31 AM
MECHTRIX
  • 416 POSTS
first " start the car and while its running " check it with a volt meter you shuold get 13.5 to 14.9 volts {eng running }....if you do" youralternator is good .....if not turn it off and check it for a parisitc drain ...disconect the ground [black ] cable then get a test light " connect one end to the bat post and one to the ground cable if it even faintly glows you have a short....good luck " i hope i helped"
Feb 4, 2009 at 6:11 PM
