1973 Volkswagon Beetle 5 speed
1973 VOLKSWAGEN
RODNEYD
  • 8 POSTS
Hi, I have a 1973 Volkswagon Beetle 5 speed and it has a problem. It is getting spark to the points on the distributor but it just won't send it to the spark plugs. Can you help me, Thank You very much.
Nov 23, 2007 at 12:23 PM
Inspect the rotor and distributor cap and also the the coil wire. Is the point gap adjusted properly?
Nov 23, 2007 at 12:34 PM
Inbox :: Message
To: rasmataz
Posted: Fri Nov 23, 2007 10:22 pm
Subject: 1973 Volkwagon beetle
Thank you for replying to my question. See we had the engine off of it and put a clutch kit on it and some people told us their is a certain way to time a Volkswagon but I don't know how. But we checked everything though.Thank You
Pull the coil wire from the distributor and ground it to the engine and crank it over -do you have spark? If so replace the rotor/cap it has to go thru there to get to the plugs. Inspect the button on the cap/rotor could be burned-off.
Do you have the coil wired properly?
Nov 23, 2007 at 2:30 PM
