1972 Volkswagen Beetle head gasket
1972 VOLKSWAGEN
BLINKBREAKING
I have a 1972 Volkswagen Beetle that has a little over 100,000 miles on it. I was wondering if anyone knows what the estimated cost to change the head gasket would be?
Apr 18, 2006 at 12:56 PM
MIKEYDEP
  • 29 POSTS
there is no real "head gasket"
sometimes there is a copper (if i remember correctly)
ring that sits between each cylinder and the head.
if you're experiencing oil coming from between the head and cylinder, you need to re-torque the heads.
if you find a bolt that just keeps going round and round, you have a pulled stud.
pull the motor, remove the valve covers, and see if any of your studs are loose....
most of the time, a pulled stud will make it sound like a thrown rod, because the head loosens and things start to bang around...this can also sound like a big ole hole in your exhaust..
you can find replacement studs at most import places for not much, a reputable air cooled vw mech shouldn't charge much for this procedure....
Oct 13, 2007 at 12:30 AM
