2007 Volkswagen Jetta Smell
2007JETTA
  • 2007 VOLKSWAGEN JETTA
  • 6 CYL
  • FWD
  • 20,000 MILES
When I turn on the A/C it smells like dirty feet or bad cheese for about 10 minutes before it gets bearable. I have read other jetta owner reviews that have noted a similar problem and said that cleaning the coil did not help. Any ideas?
Wednesday, July 15th, 2009 AT 7:18 PM
STEVEW84
  • 673 POSTS
You probably have a dead mouse in your car. Do you let your car sit for long periods at a time? Do you live in the sticks?
Thursday, July 16th, 2009 AT 7:07 AM
PELTIER1234
[quote="2007jetta"]Air Conditioning problem
2007 Volkswagen Jetta 6 cyl Front Wheel Drive Automatic 20,000 miles
As I read on CHrysler forume the cure is you buy sprayable Lysol (which is a bleach or chlorine solution), find th HVAC INTAKE! Opening, start HVAC on full, wait 1 minute to get the evaporator fins presumably wet because the moisture condences, spray into the intake. Also check if rubber nipples discharging the water under the car are not clogged.
Monday, July 20th, 2009 AT 7:54 PM
PELTIER1234
Another idea. Once I spilled from canned caussage can into the carpet. The roten eggs smell appeared in 1 week and lasted one month. Just wait then
Monday, July 20th, 2009 AT 7:58 PM
