2006 Volkswagen Jetta power window problems
50,000 MILES • 4 CYL • 2WD • MANUAL
SAVINGPACO
2006 vw jetta driver side power window wont work. I replaced the motor and I still hear a clicking sound when I push the button. I can operate all other windows through the drivers side window switch. I have taken a look at the switch and it doesn't show any signs of being the issue. Any other ideas on what could cause the motor to click and not work before I buy a switch?
Jan 11, 2010 at 4:41 PM
TDAVIDSON
just had this problem at the shop. the harness that goes through the door had a bad pin. check the wires over real good and make sure the pins are making good contact. if you check for voltage at the motor it will be a little low. good luck.
Feb 11, 2010 at 10:49 AM
