2005 Volkswagen Jetta Driver door wont work
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
LICHA15
All the electrical stuff on the driver door wont work, the power window, the locks, to open the trunk and gas tank. and when door is closed it marks that it is open and makes the beeping noise all the time your driving. Also its marking that the air bags are off. What should i do?
Jun 16, 2010 at 8:39 AM
PETERBOYES
Hi Licha.
I have the very same problem with my 2006 2.0T with the drivers door. Were you able to find a solution? If so do you mind sharing what it was?
[quote:a8ee7c05ae="licha15"]Electrical problem
2005 Volkswagen Jetta 6 cyl Four Wheel Drive Automatic 80,000 miles
All the electrical stuff on the driver door wont work, the power window, the locks, to open the trunk and gas tank. and when door is closed it marks that it is open and makes the beeping noise all the time your driving. Also its marking that the air bags are off. What should i do?[/quote:a8ee7c05ae]
Jun 26, 2010 at 10:13 AM
