Car will jerk when I accelerate
Z1C4Y7
Four cylinder two wheel drive automatic 124,000 miles.
Dear 2CarPros:
The car will jerk when I accelerate a little bit hard from a stop. No engine check light or other malfunction light comes on at all. It is doing this when I feel that it is changing from the second gear to the third gear. It does not jerk at all if I accelerate slowly. Here is a little bit more information about the car. The transmission fluid is for lifetime according to the dealer. The car has a distributor-less ignition system. I have performed all the schedule maintenance. I use high quality fuel all the time. Please help me about what might be the problem or where I should start to check if I decide to bring the car to the dealer.
Jay
Thank you very much for you help.
Feb 15, 2010 at 6:51 AM
  • 75,988 POSTS
This sounds like the engine is misfiring. I would change out the spark plugs to see what happens.
Here is a guide to help you.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Cheers
Feb 15, 2010 at 7:34 AM
ANDREA77
I replaced every filter , plug and wire and air flow things I could think of and in the end it was only the engine speed sensor that had to be replaced. once that was done she drives like a dream again.
Oct 7, 2015 at 11:15 PM
JOKERJR426
I did the plugs and BAM the problem is gone and i am getting way better mileage.
Feb 8, 2018 at 5:10 AM
