2004 Volkswagen Jetta running hot
58,000 MILES • 4 CYL • FWD • MANUAL
NNAELLEHCAR
My car is running hot and someone told me that their might be an air bubble somewhere how could that be fixed
Mar 29, 2009 at 9:46 AM
DR LOOT
  • 2,311 POSTS
I can't remember but I will find out if there is a bleeder on your vehicle, but to play it safe I want you to check the radiator for a screw (it will be a plastic) and the thermostat housing (it will be out of brass) see if there is a screw that you can loosen to remove the air. you need to be more specific with me, I am not a psychic mechanic, tell me if you been adding coolant ? if there is a leak? and how all of a sudden it started to get hot? you're not telling me the whole story.
Mar 29, 2009 at 4:14 PM
