HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Volkswagen
Jetta
Engine
Cylinder Head
Gasket
Blown
2004 Volkswagen Jetta headgasket
DANNNN
MEMBER
2004 VOLKSWAGEN JETTA
4 CYL
FWD
AUTOMATIC
70,000 MILES
Is it commen for these engines to blow head gasket at 70000miles
Tuesday, May 26th, 2009 AT 11:52 AM
DANNNN
MEMBER
SPONSORED LINKS
Tuesday, May 26th, 2009 AT 11:56 AM
Please
login
or
register
to post a reply.
Related Cylinder Head Gasket Blown Content
2002 Volkswagen Jetta Blown Head Gasket
What Is The Repair Cost (parts & Labor) To Replace The Headgasket In This Vehicle?
Asked by
kyleperrin
1 ANSWER
2002
VOLKSWAGEN JETTA
GUIDE
Cylinder Head Gasket Blown Test
Diagnosing a blown head gasket in an automotive engine requires a systematic approach to ensure accurate results. This guide will walk you through the necessary steps to...
While Doing A Boost Leak Test I Noticed The System...
While Doing A Boost Leak Test I Noticed The System Would Not Pressurize Past 5 Psi. Does This Mean That My Head Gasket Is Bad And/or Leaking...
Asked by
Anonymous
1 ANSWER
2004
VOLKSWAGEN JETTA
Changing Head Gasket
I Have Two Questions #1 I Did Not Do A Compression Check But I Suspect A Blown Head Gasket, Car Overheated Several Times And There Is Oil...
Asked by
Joaquin Arroyo
1 IMAGE
1999
VOLKSWAGEN JETTA
1996 Volkswagen Jetta Water Miixed With Engin Oil
Hi. The Machanic Changed My Cylinder Head Gasket And Now I Notice That The Motor Oil Is Mixed With Water. What Engin Damages Can This Cause...
Asked by
tourmaline
1 ANSWER
1996
VOLKSWAGEN JETTA
2001 Volkswagen Jetta
2001 Volkswagen Jetta 4 Cyl Manual My Oil Is Leaking Into My Radiator, I Was Told That I Needed A Head Gasket But I'm Unsure If This...
Asked by
missp31
2001
VOLKSWAGEN JETTA
VIEW MORE
SPONSORED LINKS
Coolant Mixing With Engine Oil
Oil Change and Filter Replacement Ford Focus
Mass Air Flow Sensor Service
Online car repair manuals
