2004 Volkswagen Jetta code P2181 Engine cooling Performance
61,000 MILES • 4 CYL • FWD • MANUAL
WUNDRTEK
I believe the radiator fans may not be coming on. The fuse is good though. Where should I look for other possible causes? No one seems to want to give out any information as to what this P2181 code means. Surfing for answers I found that it means "Engine coolant Preformance" thats a pretty broad term. Is there a relay or switch in the fan circuit?
Apr 18, 2008 at 12:15 PM
ROGER BORST
there are a couple things, most notably the ECT 'engine coolant temperature sensor'. $40 at the dealer and fairly common problem. i just changed one. located on drivers side in line- cant miss it and takes about 5 minutes to change. on that note. after i changed it and cleared the code, it came back. so my next step was the t-stat which was about $15 and a b****. but it cleared.
the problem i now have is getting enough fluid back in it to keep the temp light off. it also now seems to be leaking from behind the engine??
Aug 20, 2008 at 6:58 AM
