3rd Brake Light
2004 VOLKSWAGEN JETTA
86,000 MILES • 4 CYL • FWD • MANUAL
CLASSICHEEPFAN
How do I replace the third brake light? I have a Chilton manual, but it is somewhat vague in regards to this. From what I read in the manual it sounds like I have to tear the whole trunk apart to replace the light.
Jul 12, 2009 at 1:55 PM
STEVEW84
  • 673 POSTS
You should be able to get the bulb through the trunk. Open you trunk and stick your head in it. Look at the top and see if you can spot the bulb. If not then you have to take the cover off the 3rd brake light assembly to get to it.
Jul 16, 2009 at 12:10 AM
