I have a 2004 TDI Jetta with 197000 miles on it. At 30000 I noticed light on coolant low and check engine light came on which was the code for the EGR valve. The coolant loss got steadly worse. Checked for white smoke, none, checked in and under car, took it to two mechanics with no help. At 35000, I hit a deer in front and while getting fixed the guys changed out the egr valve because the check engine light was on. I never had any more coolant loss after that. Also Volkswagen sent me a recall notice on a faulty egr valve but mine was okay then so I never took it in. Also I have never been able to get the check engine light to turn off after clearing it. Hope this helps.
Friday, September 4th, 2009 AT 11:21 AM
