2003 Volkswagen Jetta why is my brake pedal spongy
56,000 MILES • 6 CYL • FWD • AUTOMATIC
T8S15J00
i need to pump brake pedal sometimes
Jul 4, 2008 at 2:27 AM
KHLOW2008
  • 41,812 POSTS
Hi t8s15j00,
If the first stroke is low and subsequent stroke becomes higher, the brake linings might be too far, you need to check adjustment.
If it sinks when depressing pedal, the master cylinder is faulty and needs to be repaired or replaced.
Check fluid level first.
Jul 5, 2008 at 5:23 PM
