2003 Volkswagen Jetta Sputtering and occasional stalling fu
83,000 MILES • 4 CYL • FWD • AUTOMATIC
VINMAN323
My Jetta will sputter and sometimes stall when the fuel gage reads below half tank. I have used the mileage counter to see if the gage is not correct, but the level seems true. I would also measure fuel quantity by the amount going in on a refuel. There is no engine light. Again it only happens when fuel level is below half tank. Very Puzzled and wondering if you have any ideas?????
Replaced fuel filter and air filter
Aug 19, 2009 at 9:52 AM
KHLOW2008
  • 41,812 POSTS
Hi vinman323,
Thank you for the donation.
From the symptom description I believe the fuel pump is the cause of the problem.
Check if the fuel pump strainer or connecting hoses are bad resulting in air being sucked into fuel lines when level drops below the 1/2 tank mark.
You can access the fyuel pump by folding the rear seat back forward and removing the fuel pump access hole cover.
Aug 20, 2009 at 5:52 AM
