What do Codes P0420 & P0322 mean how do I fix it?
150,000 MILES • 4 CYL • 2WD • MANUAL
SPENCEB
Car starts sluggishly, during shifting or driving RPM can't go above 4000 because then it shuts down. Check engine light on. SOMETIMES, idling at a stop with AC on, the engine will shut down. Code computer says Ignit/Distrib -Engine Speed Circuit no signal* Is my crankshaft sensor bad or do I need a new catalytic converter?
May 23, 2010 at 6:01 AM
The P0420 is saying that the converter on the exhaust is not reducing the emissions to the proper level. This is called a cat inefficiency and normally you need to replace the converter.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Basically if the engine is sluggish as well, then I suspect the converter is plugged.
I would start with this code and then see if the P0332 which is a misfire code indicating the ignition system is the issue, but that may clear up once the converter is fixed.
I would pull an upstream o2 sensor and find out if the engine runs better than that shows that the exhaust is restricted.
I attached the info below from the manual that will help with replacing this.
Please run through this info and let us know if you have other questions.
Thanks
Sep 25, 2021 at 8:07 AM
