2002 Volkswagen Jetta timing belt
106,000 MILES • 4 CYL • 2WD • AUTOMATIC
RHOLLA8
I drove my car home from work, turned it off, went to start it the next morning and it wouldnt start, its an 02 jetta with a diesel motor. I had it looked at and was told it was the timing belt thats broken, since it broke just cranking for startup do you think it bent any valves or did any other damage?
Jan 7, 2008 at 3:51 AM
EXOVCDS
  • 1,882 POSTS
I know this is an old post, but in case someone else is reading this...
Being a diesel (TDi) engine, yes, the likelihood of engine damage
is very high.
Diesel engines have high compression... to achieve high compression,
there is little room between the pistons & valves in the combustion
chambers.
So when a belt breaks, the pistons go up & down as they normally
would, but because the belt is broken, the valves above the pistons
no longer extend or retract as they should.
Valves that are in the extended position, then come in contact with
the piston... which results in the valves getting bent.
At best, there will only be bent valves that need replacing (along
with valve guides after removing the cylinder head), and at
worst, there might be cracked pistons or bent connecting rods as
well
as a cracked cylinder head.
Before removing the cylinder head, one can set each cylinder to TDC
and then perform a cylinder leakdown test to test for loss of compression... or install a new belt to see if the engine starts
and how rough it runs.
Thomas
Mar 10, 2012 at 6:32 PM
