Hi there,
Thank you for the donation.
This may be low fuel pressure on start up, if the pressure is to low and you try and start it up, it will be starving for fuel till the pump picks up pressure, first thing to do is replace the filter and have the fuel pressure checked on a cold start up, also you can do a basic check yourself by tunning the key to run (don't start it) sit for a few sec then turn off and then re start, if the fuel pressure is low this will pick it up before you start, try this.
Mark (mhpautos)
SPONSORED LINKS
Saturday, September 12th, 2009 AT 9:53 PM
