2002 Volkswagen Jetta Shifting
84,000 MILES • 4 CYL • 4WD • AUTOMATIC
COCO77385
Recently my shifter has gotten out of whack and Drive has now moved to 4th gear. The slats in between wrinkle when I try to move out of park. I thought maybe I could just get them back on track, but I don't even know how to get the casing open to start.
Sep 17, 2008 at 9:41 AM
2CARPRO JACK
  • 11,533 POSTS
If it has a full center console you will have to remove the entire thing to gain access to the shifter to repair it.There should be screws in the sides and at the bottom of the storage compartment. If no console, the housing should have screws in the side that hold it on, and the shift knob will probably have to come off too, there may be a set screw in the front of the knob that holds it on
Sep 18, 2008 at 1:09 PM
COCO77385
Can anyone tell me the parts name? I don't want to look crazy at the dealer repair shop by calling it the slats that slide.
Sep 19, 2008 at 11:21 AM
2CARPRO JACK
  • 11,533 POSTS
Probably a shifter bezel. The parts person can bring up a picture of the shifter and you can point at exactly what you want. We do it all of the time
Sep 20, 2008 at 12:31 AM
