2002 Volkswagen Jetta mil engine light code p0322
10,000 MILES • 4 CYL • FWD • AUTOMATIC
NASCARBOBBY18
Had the code read for my 02 jetta when the light came on. Code p0322 came up( ignition distributor engine speed input circuit) Car stalls at sudden stops, but restarts with a little hesitation. Research that I have done leads me to the ckp sensor(crank sensor) what is your take on this, and where is it located on the engine. I have the 2.0 engine. Thanks
May 31, 2008 at 7:23 AM
EXOVCDS
  • 1,882 POSTS
I know this is an old post, but if someone else is reading this...
The engine speed sensor or crankshaft position sensor is located
to the right of the oil filter housing. The sensor is bolted to
the engine block via a single bolt.
Feb 19, 2012 at 3:49 PM
