2001 Volkswagen Jetta P071 codes
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
MJCASSETTA
What is the fix for p071 code (too lean). Also what is the warranty for the 2001 Jetta??
Sep 16, 2008 at 3:47 PM
  • 75,988 POSTS
P0171
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
Sep 16, 2008 at 4:18 PM
