2001 Volkswagen Jetta no gas reaching injectors
2001 VOLKSWAGEN JETTA
100,000 MILES • 4 CYL • FWD • AUTOMATIC
RAMDOT88
  • 5 POSTS
hello thanks for any help--changed the fuel pump-fuel filter-fuel pressure regulator and not getting any fuel to the injectors-car just stopped working-not getting any gas to come out the fuel tank even with a new fuel pump,i can hear it whinning but no gas goes to even the fuel filter.any help would be great. Thanks R.M.
May 2, 2010 at 6:01 AM
You need to inspect the fuel pump and bench test it in a fuel container be extra cautious doing it
May 2, 2010 at 8:40 AM
RAMDOT88
  • 5 POSTS
[quote:4d6d461d73="rasmataz"]You need to inspect the fuel pump and bench test it in a fuel container be extra cautious doing it[/quote:4d6d461d73]
Thank you for your time-I bought the fuel pump and its brand new but im going to take it out---any tips on testing?
May 2, 2010 at 10:40 AM
What liter and is it turbo, gas , or diesel engine??
May 2, 2010 at 5:32 PM
RAMDOT88
  • 5 POSTS
its a 2001 vw jetta-regular gas--its got me puzzled--put in a new fuel pump-took it out twice already to test it and when i turn the key i could hear it whinning but its not pumping any gas to even the fuel filter--put a new fuel filter and even the pressure regulator--i dont know what else.any help would be great. Thanks R.M
May 4, 2010 at 5:03 AM
If its hooked-up properly in the tank and its coming on and not producing pressure its no good.
May 4, 2010 at 10:36 AM
RAMDOT88
  • 5 POSTS
Thank You for your time--do you mean that even though i can hear it coming on that it would be no good? Im going to take it out and test it in a bucket of water-Its safer than messing with gas and I just have to make sure i get all the water out if its working.Thanks again---RM
May 5, 2010 at 2:35 AM
-do you mean that even though i can hear it coming on that it would be no good? If its coming on and its not pushing fuel its no good manufacturer defects-
May 5, 2010 at 2:37 AM
RAMDOT88
  • 5 POSTS
[quote:13e9a52ea3="rasmataz"]-do you mean that even though i can hear it coming on that it would be no good? If its coming on and its not pushing fuel its no good man
ufacturer defects-[/quote:13e9a52ea3]
OK now i've heard it all--went to take out the fuel pump but it started raining--I opened the drivers side door and I heard the fuel pump "whinning"-No keys in the ignition.opened it again and nothing,waited 15 minutes and it did it again.Can someone shoot me please. RM
May 5, 2010 at 8:48 AM
