2001 Volkswagen Jetta Gas thru A/c
DUBLIN
Smells problem
2001 Volkswagen Jetta 6 cyl Front Wheel Drive Automatic 95k miles
I was wondering if u can help me out with my question:
i was driving on a local street, decided to overtake someone and floored the gas pedal, when i did that i smelled gas thru the ac. and the folowing day my check engine light goes. when the mechanic checked it, it said evap leak detected (gross/no flow).
the mechanic said it was the compensator valve, might that be the problem ??
Jan 27, 2009 at 3:57 AM
JNOVACK
  • 723 POSTS
I am not finding a compensator valve for fuel systems they are all for brake systems it sounds like you may have a fuel leak check all fuel lines and fuel injectors for looseness make sure all the clips are on all injectors
Jan 28, 2009 at 12:27 PM
