2001 Volkswagen Jetta Fuel
2001 VOLKSWAGEN JETTA
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
MAGIAMPIETRO
Car is cranking but not staying on.
I have already checked fuel filter, seems fine.
Is the next step the fuel pump relay & where is it located?
Jun 4, 2010 at 12:03 PM
Check the fuel pressure to rule the fuel pump if okay check and test the throttle actuator, throttle position sensor and mass airflow sensor to include the EGR valve-
Jun 4, 2010 at 12:17 PM
