The brake lights will not turn off, even when the car ignition is off. I have to remove the fuse to prevent the battery from draining down. I tried manually pushing in on the metal plunger on the switch that contacts the brake pedal, but nothing happens. There is an "EPC" trouble light on the dash.
Sep 29, 2009 at 8:04 AM
