2001 Volkswagen Jetta battery and alternator
2001 VOLKSWAGEN JETTA
110,000 MILES • 6 CYL • FWD • AUTOMATIC
CHRIS.HURD
Hello
I just had a new alternator and battery put in my vr6 glx 2001 jetta. It drove just fine the first and next day and today it would not start. You can jump start it and it will stay running . You just can not shut it off or it will not start again. The battery has been tested it is brand new and it reads fully charged, the alternator is new and it reads ok. What else could be wrong? The alternator is a 120 amp if that info is needed. Is there a relay that might not be working or a wire that is shorted?
Thank you
Chris Hurd
Mar 22, 2008 at 4:12 AM
KTNGUYEN
I have the same problem as you have.
Do you know how to fix the problem?
I replace a new battery, but still not hoding the charge from Alternator.
Thanks
Ky
email: knguyen@yahoo.com
[quote:69f1cfbeff="chris.hurd"]Electrical problem
2001 Volkswagen Jetta 6 cyl Front Wheel Drive Automatic 110000 miles
Hello
Thank you
Chris Hurd[/quote:69f1cfbeff]
Oct 8, 2008 at 11:07 AM
