2001 Volkswagen Jetta
97,000 MILES • 4 CYL • FWD • MANUAL
BNALEWANSKI
check engine light was on, code came up as P0341 to replace cam shaft sensor. Car seemed to lack power. Replaced cam shaft sensor, timing belt,spark plugs and oil. All tiiming marks were aligned. When code is reset by auto parts store and then driving away code stays off. As soon as you shut car off and restart code reappears. Car still lack power as well as check engine light is on. What could be the problem and how do I fix this problem.
Feb 14, 2010 at 12:10 AM
DOCFIXIT
  • 18,828 POSTS
Hi Check voltage on connector should be 4.5VDC see diagram
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_8.png
Thanks for donate
Feb 15, 2010 at 4:55 AM
