2001 Volkswagen Jetta
2001 VOLKSWAGEN JETTA
GRNFRK711
Transmission problem
2001 Volkswagen Jetta 6 cyl Automatic 89.000 miles
I have a 2001 v6 Jetta. I have had it for about a month and it just started acting up a couple weeks ago. I took it in to a vw specialist and they said the prolem was my trans fluid was too full so they flushed it and put new fluid in. Well a couple days later it started acting up again. When i get going about 50mph my rpm's will go clear up to 4 and stay there till i hit around 20mph then my rmp's wil drop to 2.It seems to that it doesnt want to shift. I told the specialist this and they said nothing is wrong. What is wrong? How can i fix it?
Sep 16, 2008 at 1:56 PM
EAFISHER1254
Im having the same problem. If you happen to figure it out lemme know, Ill do the same. There is 3 different sensors,you might try one. speedometer transmitter sensor,AT speedometer sensor, and oxygen sensor. Good luck!!
Sep 28, 2008 at 7:54 PM
GRNFRK711
i took it to a vw specialist and sfter they did a tranmission flush for 200 they relized that wasnt the problem, they told me that there is a peice in the tranny that is broke, like a cover for some wires so it screwed up the wires and thats y it wont shift. It cost me 500$ to fix it and it runs really good. So i would take it in and have them check in the tranny for pieces broken or wires fried. if that doesnt fix it they told me i would haave to replace the tranny for around 1200$
Sep 28, 2008 at 11:02 PM
